It was suggested I reduild my ailerons, so they are of the plane and in the shop.
The right ailron is striped of the fabric and I found:
A corroded cross brace on the in board end.
What material are in them? 4130 or 1010?
Crushed wood under the center hingemount and control road bracket.
Is what cuase for a new spar?
The rest of the wood spar is in good shape needs a coat of varnish and new plywood under the hinges.
Some minor surface corrosion on the metal Alodine will take care of what.
Renailing the Metal to the spar. Can I use brass nails or do they have to be steel?
