Well I got the Taylorcraft to the airport installed the wings, Rigged it and went over it with a fine tooth comb. Readjusted the ailerons so tha they were level with the wing. I wanted to taxi around a bit before tomorrow or Thursday when the IA shows up. This is my first time hand propping an engine other than the few times I did it at home without the wings. I read plenty on the procedure. This is what I came up with.
1. Set brakes.
2. Mags off
3. Turn on fuel
4. Prime 2 or 3 times
5. 2 turns of the prop (no more.)
6. Throttle all the way out.
7. Mags on.
8 Prop (I prop from behind on the right side).
Ran 1 sec maybe 2.
9. turn mags off
10. 4 through 8
Never got much more than a prumf after that.
Did the plugs frost over?
Flooded out?
Fuel still runs out the carb air box. I am going to go with a different needle and seat.
I had it good and warm, heated pad on oil and in a heated hanger for 2 hrs. covered.
Is winter starting harder than summer?
Dan
1. Set brakes.
2. Mags off
3. Turn on fuel
7. Mags on.
Ran 1 sec maybe 2.
9. turn mags off
10. 4 through 8
Flooded out?
Dan
