I am considering an engine upgrade for my L2-B. Now that the conversion STC is available, I need to decide which engine to use. First, I can't afford a Don's dream machine engine that everyone seems to rave about. I probably will have to find a runout engine here in Alaska and overhaul it myself.
I hear that a C-90 is the best engine to use because of the prop availabilities and the most desireable power curve for this particular application. The O-200 is more readily available but is heavier. I do not plan to use a starter or generator so that is not a factor.
C-85's seem to be more plentiful than the C-90. Can the C-85 be converted to a C-90?
Finally, if the future allows I may want to put floats on it.
Any suggestions out there?
Bob
Bob
