I'm being logged out to soon
  • I'm being logged out to soon
    Is there a known period of inactivity after which the system logs you out?
    I couldn't find where I personally could change this value so I assume that
    it is done automatically .
    Seems way to short to me as I will always have to log in the second time while trying to make a reply or post a new topic.
    Can this be lengthened by the administrators? All other forums like this one
    that I frequent don't seem to have any time limits. In fact I can close the
    program and go back in later that day and still be logged in as long as I didn't log in from a different computer.
    I will try to send this now and will have to log in for the third time.:tdown:
    Actually didn't have to log in this time.
    Robert Bradbury
    BC12D Experimental
    C-FAJH C90
    Sen. 74X39 prop
    Seaplane 1650 Floats
    Re: I'm being logged out to soon
    I have had that same problem also. If I take more than about 5-6 minutes to compose a posting, it tells me to log in again.
      O.K, so it's not only me. I don't seem to remember this happening since the Forum started but did start sometime later on . I wonder if we can have this
      issue dealt with?
      Robert
      Robert Bradbury
      BC12D Experimental
      C-FAJH C90
      Sen. 74X39 prop
        It has never happened to me, I get on some times and get distracted ( actually do some work!) and forget I am on, notice I have been here for an hour or more with no activity from me and I am still logged in. As a matter of fact I never have to log in; at all, ever! LL
          Maybe it is the "cookie factor". I always keep cookies turned off. I have to log in with my secret code everytime, but I just don't like having cookies on my computer. Larry you obviously have your cookies turned on or else you would have to enter your info every time you log on. I would be curious to know if only those of us with cookies turned off are the ones being logged out too soon.
            Robert B asked me off-line:
            Originally posted by Robert Bradbury
            Would you mind having a look...?
            I will...but it's the first time it's been mentioned to me. I don't have the problem myself (Win98 [home] or XP [work]). An email or PM to Admin (Bob Ollerton) might elicit a more prompt response, since I'm a forum numpty when it comes to the software.
              Hmmm... That's never happ
              NC29624
              1940 BC65
                I have XP at home and office as well. I will check the cookies to see if that
                as mentioned might be the problem.
                Robert Bradbury
                BC12D Experimental
                C-FAJH C90
                Sen. 74X39 prop
                  I turned on the cookies and it didn't make a difference. I clicked on apply so I
                  assume I wouldn't have to restart . Anyway, hopefully someone will come up
                  with a solution. Obviously it is computer or personal option setting if some are
                  not having the probem and others do.
                  Robert
                  Robert Bradbury
                  BC12D Experimental
                  C-FAJH C90
                  Sen. 74X39 prop
                    Its an XP setting, I have been gone for over a month and was still logged on when I got back...Tim
                      I am running Norton and do not worry too much about cookies. I also run Lavasoft AD-AWARE free that watches little stuff like pop ups and cookies. I can safely say I have not had a virus get through in several years. If the cookie is one of those that tracks your moves Ad-aware notifies me. One or the other other always catches it. Sometimes a page will not load properly but it tells me so and I have the option of turning off the firewall for a bit if I feel it is OK. Larry
                        There is no time limit for being logged in that I am aware of; at least not in the forum software.
                        There IS a time limit to complete a posting or reply. Posts are locked up while being edited. The time limit is to prevent them from remaining locked up for ever. I will look at extending the time value.
                        Although I am not positive I understand whats happening to you.
                          That's exactly what happens to me. I start writing a post, and if I don't finish it and submit it within a few minutes, I have to log in again before it can be submitted. ALSO, when this happens, I temporarily lose the screen where the post was written. I log in, which gives me a new blank screen, then when it says "thank you for logging in" I have to hit the "back" button two or three times to get back to my newly written post, and hit "submit" again, then it gets posted.
                            I think I had to log in once back in March, or was it April?
                            New Yoke hub covers
                            www.skyportservices.net
                              Same here. Someone suggested that it is a XP setting which I haven't investigated yet. Another said it was a cookies setting but I have since
                              tried that and it doesn't help.
                              Robert Bradbury
                              BC12D Experimental
                              C-FAJH C90
                              Sen. 74X39 prop
