specs. F-19
  • specs. F-19
    Can anyone tell me how to find specifics on the history of manufacturer designs/options.
    I am repairing a storm damaged F-19 with what appears to be original Lycoming 0235 and disc/toe brakes. It has low time and little (0) paperwork.
    Tom
    Re: specs. F-19
    F19's only came with Continental O200 I believe. F21's and F22's had Lycomings. The Type Certificate can be found on the home page of this site under Technical Info.
      Re: specs. F-19
      how about ser# , n number, data plate?? All F-19's were 0-200 .
      e-mail me direct fbarber@alliancelink.com
      taylorcraft@neo.rr.com
        Re: specs. F-19
        If it is a Taylorcraft, with a factory 115 hp Lycoming in it , there should be a counteweight in the tail section. I do not recall exact weight or location, but i am positive, others on this forum will be able to tell you. Marv
        Marvin Post TF 519
          Re: specs. F-19
          It is 7 lbs and mounted right in front of the tail post.
            Re: specs. F-19
            Tribe,
            I have seen this airplane in person and it has all the tell-tell signs of an F-19 but with an 0235 mounted on it. Maybe it's a prototype or one of the very first F-21's.
              Re: specs. F-19
              The F-21 WAS an F-19 with a Lyc. 118 HP I flew the tests.
              No tail ballast required. What does the ser# or data plate say??
                Re: specs. F-19
                From the Type Data sheet :
                "III - Model F21, 2 PCLM (Normal or Utility Category), Approved July 2, 1980
                The Model F21 is similar to the Model F19 except for the installation of a Lycoming 0-235-L2C engine, baffles, cowling,engine mount, and hydraulic brakes. "
                No F-19 had the toe brakes from the factory. The ballast was later on. Read the TC 1A9 . ALL the placards are listed on it. bye
                  Re: specs. F-19
                  Forrest,
                  This one did have toe brakes .
                    Re: specs. F-19
                    Tom
                    Does it have the large wing tanks ?
                    Robert Bradbury
                    BC12D Experimental
                    C-FAJH C90
                    Sen. 74X39 prop
                    Seaplane 1650 Floats
                      Re: specs. F-19
                      That would be a F-21A. The earlier F-21's had the small tanks and 12 gal header. I don't know that there was a tail weight with the large tanks since removal of the header tank would move the CG back.
