Can anyone tell me if the snap ring that is inside the tapered crankshaft is a special airplane-opnly item or if there is an industrial equivalent?
You guessed it, when I tried to remove the prop the worn out snap ring jumped out of the grooves. I am assuming a new, sharp, not-worn snap ring will do the trick.
I'm simply wondering if this snap ring was an industrial or automotive part used by Continental or Taylorcraft, or if it was custom made for this application.
Anyone that has anew one lying around is cheerfully urged to contact me
![Smilie](https://vb.taylorcraft.org/core/images/smilies/smile.png)
