Flat tail wheel tire
  • Flat tail wheel tire
    My tail wheel is going flat. It says 2.80/2.50-4 on the side. Can I buy a new tube from somewhere? I checked Wag Aero and couldn't find one.
    Danny Deger
    Re: Flat tail wheel tire
    Desser tire has them. Should be around $15.00. Its a real common tire. Tim
    or try http://www.aircraftspruce.com/catalo...wheeltires.php
      Danny:
      Here's a little trick that may or may not help:
      40 years ago a friend that worked in a tire shop told me that when you have a slow leak, it's most often caused by a leaking valve. You can test it by inflating the tire and dropping a glob of spit (yes, spit, outa your mouth) into the end of the valve stem. If a bubble forms you have a leaking valve.
      If so, go to the WalMart auto department and get a tire valve kit...it contains a little tool for installing/removing the valve core and a half dozen new valve cores, costs $1.69 or so.
      Bob Gustafson
      NC43913
      TF#565
        I usually just rotate my flat 180 degrees as they seem to only ever be flat on one side.
          ...or put a solid tailwheel on.. They are real difficult to get flat.
            Every flat tire I ever had always just seemed to be flat on the bottom???? Go figure.
              If you have one that is flat on top to, you will need a new tire. Marv
              Marvin Post TF 519
                Everyone blames the tire, but it is the air that is flat. Put in new air. I'll bet that the tire gets round.
                Put in colored smoke and you can see where the air is getting out.
                RonC
                N96995
                It amazes me that people who can't understand that still get to vote.
                Ron C
                N96995
                  profound Ron!
                    Oh Lord, we seem to ahve lost control of this thread. I will say that out forumn does have diversity . and really not too many nasty people, actually none lately. My Dad used to tell of filling the tire with oats and adding water to get it to swell up and run on that for a while.
                    Those tail wheel tubes show up at Tractor Supply and many other places in a pinch they can be used .
                      forrest,
                      did your dad have trouble with goats eating the tires when oatmeal was in it?
                        Flat Tire have never made me laugh so much before!:bravo:
                        But when it been flat during a race or in the rain.
                        Thanks Len
                        Foundation Member # 712
                          I thought it was "does eat oats"....
                          Just trying to figure out a way to put oats down that itty bitty hole... Works much better on radiators...
                          Bill
                          Vintage Aircraft Services
                          1943 L-2M Restorer...
                          1946 J-3 Cub
                          1941 J-3 Cub
                          1931 Buhl "Bull Pup" (2)
                          1949 Schweizer SGU-1-19
