Re: Replacement parts sources
You are quite right, of course, Mike. But the primary failure mode of all strut-braced (and pin-jointed) monoplanes is the compression [buckling] failure of the struts. That's why, by design, long struts have a jury strut somewhere along the length. It's not anything to do with tension...it's to reduce the effective buckling length.
Take a look at an aerobatic Taylorcraft or Cub...the struts are super-sized to cope with the compression (buckling) loads under negative "g".
Typically, a strut is four-times stronger in tension than in compression.
Which is one reason why any corrosion (except extremely severe and probably externally-visible) in the lower 12" of the strut is not going to affect a failure in tension: because the wall thickness is typically four times thicker than necessary. So buckling strength of pin-jointed struts (like the Taylorcraft) is a lot less affected by corrosion in what is already an over-engineered wall thickness.
In conclusion, the AD-mandated limits of permissible corrosion have not been adequately researched in terms of the failure in either tension or buckling.
(As an aside the Cub, by design, does not have a pin-joint (in the correct axis) at the lower strut end, which is why "No Step" signs are mandatory, and corrosion at the strut lower end is more significant than on a Taylorcraft.)
Incidentally 1: The weight increase (on average) of the three Taylorcraft I have re-strutted with Airframes struts is 9lbs in total.
Incidentally 2: Mike, your recent (but much later than promised...I guess that's between you and the purchaser) strut delivery to Leicester arrived this week and bolted up OK.
