Tail Numbering
  • Tail Numbering
    Are the tail numbers done in dope (on a ceconite/dope finish) or another type of paint? Do you favor the purchased paint masks or make your own masks? Looks like a set of masks will only run a little over $40. Thanx
    MIKE CUSHWAY
    1938 BF50 NC20407
    1940 BC NC27599
    TF#733
    Re: Tail Numbering
    You can do them in dope or some other approved paint method allowed in your covering STC. Personally I use vynel stickers made by the local graphics shop. Work great,hold up forever(if you use the good vynel),they can use computer grapics to make them any style you like, and they are sooooo easy to put on. Takes a few minutes and your done....no scuffing,no masking,no mess. Plus you can have them made up for under a $100 bucks in most places.
      Re: Tail Numbering
      Go to any sign shop and 2" custom cut decal numbers will cost only about $40.00 in just about any color. Tim
        Re: Tail Numbering
        Tim,
        There is a problem with that....even the small numbers are required to be at least 3" tall. As long as you use the 3" numbers you'll be fine.
          Re: Tail Numbering
          Kevin, Take a look at FAR 45.22b1, 2" is legal if the aircraft is 30 years or older. Tim
            Re: Tail Numbering
            I was thinking they had to be at least 3" high and 2" wide...I will look it up in a few.
              Re: Tail Numbering
              Is this for your '38? If so the original numbers are 6" high, I beleve, with an NC above . You can scale off some of the factory photos in the book, page 63. You can also have an original Taylorcraft logo made, with the large "T" at each end.
              Chet Peek
                Re: Tail Numbering
                They are 5" high, which is odd until you do the math to lay them out. I have some rudders here with the original covering and that is the size they were when I measured them
                  Re: Tail Numbering
                  Tribe,
                  Well, this is an interesting topic. We start with 2" numbers, then 3", then 5 and finally 6". So, I had to down to my shop and confirm what I suspected. My original rudder from a '41 Deluxe measures 4"! Did the number size change over the years? Moody Aerographics made my mask at 4". Mike, toss a coin and call in it the air. :clue?::
                  Best regards to all
                  Glen Brodeur
                  Putnam,CT
                    Re: Tail Numbering
                    Thanx all! I have scaled several photo's and do come up with approx 5" with the "NC" above.
                    Chet,
                    Yes, this is for NC20407, my 11/38 Taylor -Young. Would it have the Taylorcraft logo on the tail?
                    MIKE CUSHWAY
                    1938 BF50 NC20407
                    1940 BC NC27599
                    TF#733
                      Re: Tail Numbering
                      I had a local sign shop do the original type with large T on front and back of
                      TaylorcrafT. Looks great, painted with dope on my '40 BC-65, NC29624, Ser. # 2466. It should be back in the air in September '07.
                      Carl Carson
                      TF# 371
                        Re: Tail Numbering
                        How much would it cost me to get a set for my airplane? I need a black set.
                        Winston Larison
                        1006 Sealy st.
                        Galveston TX, 77550
                          Re: Tail Numbering
                          MIKE CUSHWAY
                          1938 BF50 NC20407
                          1940 BC NC27599
                          TF#733
                            Re: Tail Numbering
                            Chet Peek
                            Chet,
                            You are correct(sorry I doubted). The tail numbering on pg 63 scales within a fraction of 6" high. (47 1/2" x .151)/ 1.187 = 6.04".
                            MIKE CUSHWAY
                            1938 BF50 NC20407
                            1940 BC NC27599
                            TF#733
                              Re: Tail Numbering
                              I have searched all the threads and can not come up with a source for the prewar Taylorcraft logo with the large T on both ends(as applied to vert fin). Can anyone advise if this artwork exists? Thanx
                              MIKE CUSHWAY
                              1938 BF50 NC20407
                              1940 BC NC27599
                              TF#733
