I have been trying to find a STC for a 0-200 install in a BC12D. I have found where two LSTCs have been done in Canada but the trail stops there. I cannot find who did the paperwork. Any help would be appreciated. Thanks.
STC for 0-200 in Tcraft...
Re: STC for 0-200 in Tcraft...
I just pulled out my paperwork and it says.......
Conversion of Model BC and BC12D to BC12D-85 or to BC12D-4-85.
Maybe he got something different or a separate field approval for the O-200? I could see that as there are quite a few mods on my 85 beyond the STC.
There is no mention that I can find of an O-200 on these plans........Richard Boyer
N95791
Georgetown, TX
Originally posted by Richard Boyer View PostI just pulled out my paperwork and it says.......
Use the Harer STC to install a C-85, then use the other STC to upgrade the 85 to an O-200 crankshaft.
Because the crankshaft STC does not change the model number or data plate on the engine, I think you can make a case that you are still installing "a C-85-12" engine in your plane per the Harer STC.
Or you could do the Harer STC (paperwork) first, then "add" the O-200 crank STC (paperwork) later. Then you can do the work on the airplane all at once.Taylorcraft : Making Better Aviators for 75 Years... and Counting
Originally posted by VictorBravo View Post...Because the crankshaft STC does not change the model number or data plate on the engine, I think you can make a case that you are still installing "a C-85-12" engine in your plane per the Harer STC....
there is an STC to convert a BC12 to the model 19, I will have to look it up. Tim
SA3192SO Installation of a Teledyne Continental Motors model O-200 engine and a McCauley model 1A101 propeller
SA1677NM Installation of a Continental O-200A engine, fiberglass cowling, two 12- gallon wing tanks,Last edited by astjp2; 05-16-2007, 16:34.N29787
