STC for 0-200 in Tcraft...
  • STC for 0-200 in Tcraft...
    I have been trying to find a STC for a 0-200 install in a BC12D. I have found where two LSTCs have been done in Canada but the trail stops there. I cannot find who did the paperwork. Any help would be appreciated. Thanks.
    Re: STC for 0-200 in Tcraft...
    The model 19 stc by Harer is what most people use. Do a search on here for more info. Tim
      If you have the Harer STC you can install an O-200?
      Since it was already done, I never really looked that close.....
      Is this true??
      Richard Boyer
      N95791
      Georgetown, TX
        I dont have the STC, so I have not personally read it, but that is what a friend used to install one in his '46. Tim
          I just pulled out my paperwork and it says.......
          Conversion of Model BC and BC12D to BC12D-85 or to BC12D-4-85.
          Maybe he got something different or a separate field approval for the O-200? I could see that as there are quite a few mods on my 85 beyond the STC.
          There is no mention that I can find of an O-200 on these plans........
          Richard Boyer
          N95791
          Georgetown, TX
            I used the Harer STC to install the O-200. It modifies the aircraft to Model 19 also which is a type certificate jump, and then I installed the O-200 per F-19 specs whihc is the same as a Model 19 except for engine installation. Done on a 337.
              Since Swick is now back in business, he had a seperate STC to install an O-200. Might trying giving them a call to see if they can help.
                Use the Harer STC to install a C-85, then use the other STC to upgrade the 85 to an O-200 crankshaft.
                Because the crankshaft STC does not change the model number or data plate on the engine, I think you can make a case that you are still installing "a C-85-12" engine in your plane per the Harer STC.
                Or you could do the Harer STC (paperwork) first, then "add" the O-200 crank STC (paperwork) later. Then you can do the work on the airplane all at once.
                  ...Because the crankshaft STC does not change the model number or data plate on the engine, I think you can make a case that you are still installing "a C-85-12" engine in your plane per the Harer STC....
                  Actually, there is no other case to be made. The STC to install an O200 crank (and rods and pistons) in a C85 does not alter the designation of the engine and therefore has no impact on the airframe, at least from a regularatory perspective.
                  New Yoke hub covers
                  www.skyportservices.net
                    okay, but what about actually installing a real deal 0:clue?:: 200?
                      there is an STC to convert a BC12 to the model 19, I will have to look it up. Tim
                      SA3192SO Installation of a Teledyne Continental Motors model O-200 engine and a McCauley model 1A101 propeller
                      SA1677NM Installation of a Continental O-200A engine, fiberglass cowling, two 12- gallon wing tanks,
