I want good brakes
Re: I want good brakes
Could I get a copy of those blueprints Tom? I'm going to be working on some of these brakes soon. [email protected]Originally posted by Tom Garrick View PostI have factory blueprints for the cleveland toe brakes if anyone wants a copy.
Tom Garrick
Thanks!
I would love to get a copy of any field approvals for upgraded brakes, I have one that I need to get the paperwork and I dont have any data to support the mods. Thanks Tim
[email protected]N29787
I have owned KZU for 4 years now and this year I hade almost no brakes, so thinking they are adjustable! :tup:
So I turned the little nut with the locking clip on, after removing the clip, and I got brakes, and good once!
It pulls a little wedge out sa you bring the brake shoe closer to the drum.:bravo:
If your lining is worn out, install new lining but be carefull when riviting them into the drum as it is easy warp the drum and when you have a problem.:tdown:
I have reed about the procedure on this website. Search for it and the company what sells the part!:tup:
Parker wants a god buck for there brakes!
Foundation Member # 712
I have stock brakes on mine and they work great. I had heard before I bought a Tcraft I would not have good brakes but couldn't ask for better ones.
I still like what my instructor says though about brakes on an airplane, "most" of the time if you have to use brakes it is from poor planning.
I would be interested in lookin at toe brakes [email protected]
Marc, right now its getting real hard to get field approvals. Last week I got one on a battery box installation on the firewall of a cessna 180, that I've done many times. I had to do pull tests from every way do can think of, with pictures and you name it. I used data from others that I've done and still had to do all the tests and also write a book. Customers don't like to pay for all the extra time it takes. I think its just this new PMI I've got, time will tell. As far as cable brakes, try landing on a 600 foot strip with big trees on both ends. I used to land on one all the time, at my cabin and everytime was the new adventure. The trees on one end were across a beaver pond so you would take off that way,but landing was a different story, you had to stop before the pond and many a time, I almost went in. I was adjusting those factory brakes almost everyday. Sometimes I thought I was going to put the brake pedals through the floor. I new brakes I have work great and as far as going over, you figure out real soon how much pressure to use. Here is a picture of my master cylinder installation.Attached FilesWolf Lake Aircraft Services
hey larry,thanks for the info iam working with my faa inspector can i get a copy of your field approvable jd the inspector said he has a idea how to get it pass i need to get they mod done before i move up to ak iam going to stay with 850-6 i cant afford bush wheel and if you can give me some hint to do to my tcraft i will take any advise iam glad to here there some tcraft driver are up there i would like to met you so you can show me some spots to fly well thanks for the help marc.n43643
howdy all,i just got an ok by my faa insector to do the swith to 150 brakes but i haft to use toe brakes does any have a field approvle on heel brakes if so can i get a copt my faa guy said if i can find a field approvle with heel brakes i mit get it pass. when im done i will give any one a copy of the approvle.thanks marc n43643:tup:
