rear D window Frame
  • rear D window Frame
    I need a pattern or picture of the Rear D window frame for a 46 BC12 D .
    Re: rear D window Frame
    bob wagstaff and u can reach him bettween 9am to 5 pm monday through saturday 281-471-1188
      Howdy: Send me an e-mail if you don't get what you need. I will be working on my D-frames as soon as my plexiglas order arrives and I can get you some dimensions. Doc
      Doc TF #680
      Assend Dragon Aviation
      FAA Senior AME #20969
      EAA TC #5453 / FA #1905
      CAF Life Member #2782
      "Leben ohne Reue"
        I need paterns or drawings too for rear windows for a BC12D. Thanks.
        Larry Wheelock, POB 309, Raymondville, TX 78580
          I could use a rear window drawing/pattern too. Maybe we could start a list and send it around.
          Bob Gustafson
          NC43913
          TF#565
            I have the original 1945 metal frames from mine and I am pretty sure they are the same as the later post war planes. I also have the thin metal pieces that go over it on the outside to hold the transparency in place. How do we get the info distributed?
            I also have a 1941 that had WOOD "D" window frames. Someone along the way replaced the originals with cheap pieces of outdoor plywood. I have made some really nice frames based on the holes in the fabric but there is NO WAY to tell if the shapes are right except by looking at photos. After I carved the wood frames (isn't that always the way) someone told me the original frames were laminated by winding thin strips around a form. Does anyone have the correct hole shape and outside shape of the RIGHT pre-war frames? Mine aren't in yet and I could (SOB!) throw away the carved ones and make them right.
            Need to know soon since I was going to install them this weekend!
              I have original deluxe frames I have traced for people here in the past. The were laminated originally. The 45 frames are not the same as the Deluxe frames. The 45 frame is shorter to fit inside the short headliner. The deluxe has a hatshelf which allows for a bigger window.
                Mike if you send me a tracing of the origonals I could scan them in to the computor and then email them to Forrest to save them for future use.
                Larry
                  Mike,
                  Are you looking for the short D window, or the long one that came on the later models? The tumbnail shows the short one, the attachment is the long one.
                    If I go to the trouble to put windows in I would want the ones closest to origonal. I am guessing the shorter one would be right for an early 1941 B. But at this point I have not made that decision. However I see a fair amount of interest in them here and in other posts so thought that they ought to be available to those that want them. Thanks, Larry
                      Larry
                      Pm me you address and i will send them to you
                        Mike,
                        That short window doesn't look correct.
                        mike
                          I agree with mike.The short one is not original unless they made different styles from the factory.
                            Looking at the photos in Chet's book the original pre-war window looks much shorter (top to bottom) but photos can trick the eye pretty easy. Can I get a copy of the drawings too and I will compare them to the window shape I derived from the photos. I know what WAS in my 41 isn't right, but some photos let me get several points on the "hole" pretty close.
                              It will be Monday, but I will post pics of both prewar windows.
