brakes
  • brakes
    Is there a stc for hydrolic brakes for the bc12d,s yet I heard someone was working on that
    Re: brakes
    Hi Doc, welcome to the forum.
    Why would you be needing hydraulic brakes? Obviously not on skis or floats, so you must be running BIG Tundra tyres, eh?
    Are you on Clevelands or Shins?
      Re: brakes
      the craft has shinn brakes that don't work to sute the owner it has org running gear
        Re: brakes
        ya i was wondering about the same thing today out at my local fbo saw them put small dick brakes on a j3 the owner told me that they would not nose her over when u steped on the brakes and thought i needed them on my tcraft
          Re: brakes
          I looked hard and couldn't find anything to put Clevelands on a BC-12D. You could probably get a field approval to convert to F-19 legs with straight axles and Clevelands (send me a copy of your 337 if you do!). There is a picture of a hydraulic "mock-up" somewhere on this site that looks like a great setup.
          A huge part of good brakes is consistency - grabby brakes are dangerous if you're working in really tight places. The Shinns (all drum brakes) are grabby without being very effective, even on little tires (8.50 is as small as I've ever flown). With 26" tires, you can mash on the brakes all you want without actually making anything happen.
          Tim - if you don't have enough brakes to lock your tires up, you could land shorter. If you abuse them you can get into trouble. Simple solution: don't abuse them!
            Re: brakes
            Shins worked for sixty some years back when the long runway was 1000' long why not save some money and adjust or rebuild the shins.
            Dennis Keels Foundation #400
              Re: brakes
              The hydraulic conversion I was working on has been delayed due to other responsibilities. If I had Shinn brakes I would not even consider swapping. My experience with properly setup Shinn brakes is that they are more than adequate even with 26" Alaska bushwheels. I almost put it on her nose a few times. The Shinns would lock up and skid 8.50's on pavement. The OEM mechanical Cleveland's on my F19 are not as effective.
              Jason
              Former BC12D & F19 owner
              TF#689
              TOC
                Re: brakes
                We put a set of cleveland disc brakes on a J3 cub and they work great for mamnuevering about the airport ramp in tight places on a windy day.
                My BC12D will slide the tires in the grass if you really get on them, it to has shinns but it took a lot of maintance to get,em to that point.
                hydro brakes are much less maintance and are more reliable in my opinion, just trying to help out a fellow tcart driver
                so if any one has some info on the disc brakes for a BC12D I,d be greatfull
                  Re: brakes
                  Bigdaddy: 1000' is about 4 times what I can get OUT of in my Tcart. If I had better brakes, it would also be 4 times what I can get INTO.
                  The single-puck Clevelands on my Champ won't lock my 31" Bushwheels unless I'm fairly light or on fairly big gravel, but they're still way better than any drum brakes I've ever been around. How does one properly adjust the Shinns to lock Bushwheels?
                    Re: brakes
                    I thought about an STC but the cost to develop and sell would not be cheap. I figured close to $2K just for the kit, not including installation. Swick had an STC for 5.00x5 cleavelends but he won't sell the stc anymore.
                      Re: brakes
                      I came up with over 3k without adding anything for a little profit or liability insurance. It just isn't economically feasable.
                        Re: brakes
                        Robbie Grove in California (Grove Aircraft) recently released a disk brake kit for Piper Cubs via an STC. I would think that if enough folks asked him he may do the same for the Taylorcraft. I saw his kit- they are really nice and sized for the weight of aircraft we operate.
                        As for getting in really short with the Shinns- I routinely work out of a 600 ft strip here locally with good margin but I am still on the 6.00x6's. I can hold the C85 at close to full power but I am really standing on them. I am sure the bigger tires reduce their effectiveness.
                        Eric Minnis
                        www.bullyaero.com
                        Clipwing Tcraft x3
                          Re: brakes
                          My point exactly and my figure was from several years ago.
                            Re: brakes
                            Cub already has hydraulic master cylinders with straight axles so it is just a metter of installing a cleaveland kit. Taylorcraft as you know would require considerable more parts and modifications to install
                              Re: brakes
                              I agree. If you go back to the early 2004 posts, you will notice that I wanted hydraulics too. After three years, and many landings, I have gotten used to the Shinns, and would not replace them unless the original parts were no longer available, and even then, I would make the modifications required to run the Cleveland mechanicals off a 7AC Champ. Sabrina
