Hi all, I am looking for opinions about what a `46 bc12d like this is worth.
Any clues or opinions would be appreciated.
Cont. A65, 24 gal. gas, 229 SMOH, two wing tanks, auto gas STC, sound proof kit, shoulder harnesses, dual brakes, skylights, large rear windows, F21 headliner, ELT, stainless exhaust. Panel has altimeter, 8 day clock, rate of climb, tach, oil temp., oil pressure, turn & bank, airspeed, compass, inclinometer. Has metal prop, external antenna. Looks clean.
Has the F21 type welded strut fitting on front spars.
In 1998 it had new ceconite, spars, prop, all glass.
Since `98 had new seat sling, oil temp gauge, tachometer, tires and tubes, cowl pad. All logs present.
Compression test ;
#1-75/80
#2-75/80
#3-78/80
#4-77/80
Thanks, Dave.
Compression test ;
#1-75/80
#2-75/80
#3-78/80
#4-77/80
Thanks, Dave.
