Ive got a leaky wing tanks,,what is the procedure to remove and replace these tanks? I want more range,thankswayne
removing wing tanks??
Re: removing wing tanks??
I had to remove both wing tanks and replace the outlet fitting, which is available from aircraft spruce... I have lots of pictures if you send me your email address I will forward them to you. I replaced the fabrick with Alum. machine screws and rivnuts..authorized with a 337... I have not figured out how to put pictures on a thread..this is not a tough job ,just requires patience and a few hours.Walter Hake TF#
thanks my email is dirtdobber47@tds.net send info on the stc allso thanks again wayne
