Anyone seen engineering drawings for the "strap-on" dual brakes? - Mike
Engineering drawings for "strap-on" dual brakes?
Re: Engineering drawings for "strap-on" dual brakes?
Originally posted by mhorowitAnyone seen engineering drawings for the "strap-on" dual brakes? - Mike
If we don't have the drawings, perhaps I can 'reverse engineer' one.
'Fess up, who has one in the garage from which I can get dimensions? - MikeMike Horowitz
We had this discussion a long time ago... I have a set for copy purpose. Will look for drawings too! I am running for a public office ( Lexington Township Trustee) will be very busy till after Nov 8th, 2005, then look out my brain will return to Taylorcraft stuff.Taylorcraft Foundation, Inc
taylorcraft@neo.rr.com
Originally posted by Forrest BarberWe had this discussion a long time ago... I have a set for copy purpose. Will look for drawings too! I am running for a public office ( Lexington Township Trustee) will be very busy till after Nov 8th, 2005, then look out my brain will return to Taylorcraft stuff.
Will that involve a payraise? Or is it just for the honor? - MikeMike Horowitz
When you make and install the RH brakes make a bracket up to lock them so they DON'T WORK too. When you have a "guest" in the right seat you DO NOT want them mashing the brakes at the wrong time. You ESPECIALLY do not want them mashing down on ONE brake. You can make a simple welded clip for each brake that prevents them from working on the passenger side only. I wouldn't consider a Young Eagle flight without disabling the right hand brakes.
So why do people want right side brakes??? In my case it was many years ago when I put my 15 year old son in the left seat and was letting take off and land in my 1000 ft runway at home. (WI 181) It gave me a felling of some control. He did very good as I never really used them while he was flying. Kids learn quick!! At this time I think he is in the 10K hrs and moving from the regional jets to the 717 so it all worked out. Many $$$$ latter.Karl Rigdon TF#49
Originally posted by mhorowitI know you all are out there; I can hear you breathing.
Originally posted by Tom Bakeri have a drawing of the right hand brake assy. send me mailing address i will send you a copy. tom baker
1015 Poplar Dr.
Falls Church, VA 22046
and thank - MikeMike Horowitz
Originally posted by Tom Bakeri have a drawing of the right hand brake assy. send me mailing address i will send you a copy. tom bakerLove to see it sometime if I could stop by.
NC29624
1940 BC65
Originally posted by John N43951We have a club owned BC12-D also used for flight instruction, having right hand brakes would be comforting. A copy of drawings would be appreciated. Thanks
John Waalkes,
3103 W 36th Ave.
Anchorage, Alaska 99517Mike Horowitz
