Originally posted by PA1195
View Post
Carb Ice - Continued
Why? They use the same basic engine architecture and are prone to the same sickness. Non-electric gauges are available.Originally posted by Robert Lees View Post
I'm a great fan of those in the right aircraft (JPI for example do some lovely kit), but in a hand-swung non-electric Taylorcraft, it's a bit different!
Edit: I might also add that flying over wilderness tends to create a more cautious pilot. Any help avoiding contacting the ground prematurely is a plus.
GaryLast edited by PA1195; 12-21-2019, 11:08.N36007 1941 BF12-65 STC'd as BC12D-4-85
Rob reading skills are essential. Note I mentioned above non-electric supported gauges driven only by EGT/CHT thermocouples are available. I said nothing about JPI or other glass panel units. The less expensive ones (like WESTACH) are limited to normal ambient temps if best accuracy is important. Others (like Alcor) offer better compensation. I've used both types in several aircraft as well as electric driven JPI.
But the point is information that may help the pilot and later mechanic diagnose and fix a problem is a choice I agree. There's not many rural roads and cornfields in Alaska to land on if the engine quits or looses adequate power.
Example: https://www.aircraftspruce.com/catal...SABEgKk6fD_BwE
