Brake bellcrank spring
  • Brake bellcrank spring
    image.jpeg Does anyone have a clear pic of the correct installation of this brake bellcrank spring? I should have taken a pic.
    MIKE CUSHWAY
    1938 BF50 NC20407
    1940 BC NC27599
    TF#733
    Not sure if a couple of photos here would help if you look close. Page 3 of this document. https://www.taylorcraft.org.uk/Brake-issues.pdf
      Little out of focus but you'll get the idea
        Thanx guys, that is a great help. I probably painted over those holes without even seeing them. I did redrill the two drain holes in each gear..
        MIKE CUSHWAY
        1938 BF50 NC20407
        1940 BC NC27599
        TF#733
          I just installed springs on a 46 T-Craft that I bought. There was no evidence of holes ever having been drilled for the springs.
            Mine is a '40, and yes, I painted over the holes. After finding them and redrilling, the springs fit perfectly. Thanks all.
            MIKE CUSHWAY
            1938 BF50 NC20407
            1940 BC NC27599
            TF#733
