I have a partial roll of yellow Ceconite 102 that is heavier and stiffer that std white 102. I can't find anything online that refers to the yellow color. Any ideas?
Yellow Ceconite 102
I came across this yellow Ceconite about 30 years ago (although it was in 2" pinked tape form). As others have said, I think it's pre-doped. Quite how to use it, I didn't know back then, so I discarded it, but I now believe it to be applied with Nitrate thinners (no dope required). This was before the "New Super Seam", when Ceconite used Nitrate-based adhesives.
Well, I had already covered my gear legs before I got this feedback. I will say, it bonded with New Super Seam cement beter than anything I have ever used. It shrank up just fine as well. Because of its stiffness, I made gear leg covering templates out of the remainder. Thanx formall the input!MIKE CUSHWAY
1938 BF50 NC20407
1940 BC NC27599
TF#733
It wont last, a previous customer got 4 years out of the cover job using blue river before he had to recover it...the nitrate will peel of because it will not encapsulate the fabric correctly. It was good in theory but bad in practice. Replace it now or in a few years, but you will replace it. TimN29787
Water is used as the carrier not the catalyst.Originally posted by beaverbill View PostThe Stewart System is not the same as the Blue River. Water is used as a catalyst in the Stewart System, otherwise nothing in common. And that is from Stewart Systems information I got at a learn to do it class. Stewart's is nice to work with.
No, there's nothing left of the Blue River system in Stewarts. At one point, it was a rider on the BR STC, but that was a long time ago and it's on it's own STC now, under part 23 standards. The only thing that was from any other system is the fill coat (ekofill) and that came from the old Eonex system.
