Looking for original style 1946 glove box doors. Any help is appreciated.
Glove Box Doors
Re: Glove Box Doors
Make sure to check the door and box dimensions! There was more than one box size and some won't fit in other aircraft. I have bucks for two different size doors (for the 41 and 45) and they are NOT interchangeable! Don't know if they had other sizes before 41 or after 46.
Re: Glove Box Doors
Look here at page 6=> http://www.taylorcraft.org/docs/Tayl...anual_1985.pdf
Its the 1985 parts manual and I attached page 6 only to this post for convenience.
Look at lower left corner for "INSTRUMENT & ENGINE CONTROLS FOR ALL MODELS" then look down for part number 0989-1.
It fits all models according to Taylorcraft but apparently "ALL MODELS" means 1945 and after, see NOTE at bottom of paragraph.
1946 would fit that description.
Bottom line, it should fit fine.
Dave R.
Re: Glove Box Doors
You can get new ones and new springs that match the originals from David Wenglarz. Just search his name and you will find his info as well as pictures I posted of my new panel and glove box doors. His work is flawless.Cheers,
Re: Glove Box Doors
Also found this from you Marty=> https://www.chevsofthe40s.com/detail...ash_Ivory.html
Sounds like about $20 door + $14 handle + $3 spring + shipping for handle + shipping from Dave so total maybe $50 per door??Last edited by Guest; 09-29-2017, 08:41.
Re: Glove Box Doors
I would take 1/2 of that for my door - $25Last edited by Guest; 09-29-2017, 18:25.
Re: Glove Box Doors
Well appears to be no shortage
I still have a couple, complete with handles, hinges and springs: http://vb.taylorcraft.org/showthread...ighlight=doorsScott
Re: Glove Box Doors
Thanks Dave
I was happy with the way they turned out. So happy... I didn't paint them to match the panel: https://1.bp.blogspot.com/-Nb6Hwk9Gj...0/DSCN5124.JPGScott
