I'm in the middle of rebuilding the right wing on my 46 BC-12D. I'm finally in the re-assembly stage. My question regards washout. I've found the rigging instructions on here that describe leveling the airplane and measuring 1 5/16 under the front spar - which I believe I understand. But is there any guidance for when the wing is actually being built and covered?
I trammeled the wing flat on saw horses. I've begun nailing ribs. Should I be doing this with washout already set? Or just continue with a flat wing? What about when I get to the fabric stage? My initial thoughts had been to build and cover it flat and then set the wash out with the rear strut when finished and mounted, but now thinking maybe I should have the twist already set during assembly/covering. If so, is there any guidance on how to set the washout when the wing isn't on mounted on the airplane? i.e. flat at root, raise rear spar x amount at last full rib?
