Re: Wing re-build, washout question
I'm not so sure, if only because a 30 degree twist is completely unrealistic. The actual washout (twist) is obviously an awful lot less, and the natural flexibility of the spars, the fabric and the drag/anti-drag wires will absorb any variance during construction.
As a matter of interest, when I recorded the rebuild of my wings, I made the following annotation to these two photos:
"String lines assure the straightness of the spars during trammelling. The right-hand photo shows the wing with a block inserted under the front spar to simulate the wash-out to verify that nothing alters."
(source=http://www.taylorcraft.org.uk/Brey_rebuild-Wing-structural.htm)
and then when I did my next wing, I annotated:
"The next wing is prepared for covering. One of the things very noticeable is a "set" in the wing, after nearly 60 years of washout in each wing."
(source=http://www.taylorcraft.org.uk/Brey_rebuild-Wing-fabric.htm)
I doubt the factory in the 1940's or before or since used blocks to pre-empt washout.
Originally posted by drude
View Post
