Hi All
I was looking over the Talorcraft Drawing of the instrument panel today and noticed is calls for two screws in the lower outboard corners. The drawing states "drill on assembly .093" and calls for 2 PK screws (see photo). If one drills in that location the fuselage tube gets a hole.
Mine did not have these screws, only the 4 machine screws through the control column mount. I had intended to put a couple of adel clamps in the general area where the PK screws are specified.
Just curious to know if others have these screws and if they are indeed into the fuselage tube.
Cheers
S
Cheers
S
