Re: Priming the oil pump through the relief valve?
the a65 oil pump issues have been around a long, long... long time. Before jumping off the deep end making expensive repairs we might want to ask how many if any failures have actually occurred in whole or in part due to oil prime loss issues. I could be off the mark but I'm thinking none. Loss of prime on these engines is not necessarily an indication of excessive wear. the oil pump is not a good design to start with and the distance from the pump to the oil in the tank is relatively far (more head to deal with). The is no seal on the pump cover and a tiny leak here is all that is required for the pump to drain back into the oil tank (because air can leak in past the cover).
These motors will run quite happily and safely through to overhaul complete with loss of prime, but all the normal indicators remain valid, investigate low oil pressure, check the screen regularly for signs of trouble, oil analysis if you need more comfort.
Originally posted by drude
View Post
