Adjusting Washout
  • #31
    Re: Adjusting Washout
    Prewar vs. post war measurement for the wing attach fittings after a repair? Wing spar fittings were off a little on each side? Does it really matter if you can get it to fly wings level? I would be looking at getting a prop before worrying about the wings....Tim
    I agree. The problem statement has moved around a bit during this thread IMHO.
    There are are interesting issues with wing rigging that came to light.
    But if the real question is about speed the prop seems odd.
    I run a McCauley a 70-49 on an A65. A 70-40 is too flat for an 85 hp.
    Would be interesting to know the static RPM for this setup. I get 2040 to 2100 from year to year with optical tach.
    Limit for the set up that I assume we are talking about is 2350, not under 2170
    Since the ASI is alleged to be correct I would also look a W & B just because it intrigues me.
    • #32
      Dave, your prop is too short for the 65, minimum is 72.5...
      • #33
        That is not a true statement, the seaplane prop goes to 75" on some aircraft with the same engine that the land plane is only 72" max diameter... I know that the C-150 for example has a 68" on land and a 75/38 on water....and the cub has similar requirements...It was a ground clearance issue not balance or vibration one. Tim
        Apparently the 74 inch prop is not certified/tested for vibration at the higher RPM of the 85. There was quite a discussion here on that subject a while back. Lot of people are using them anyway. Additional vibration would have to be pretty bad to notice it in a Tcraft. Chuckle.
        On the full opposite adjustment on the struts; I have close to that condition on my -85. What I can see on my wing is that one of the wingtips is shaped slightly different from the other. I have to look VERY closely to see the difference. With all that leverage, for sure that is part of the reason for the adjustment offset on mine.
        • #34
          I thought the standard 150 prop for land was 69x50.
          • #35
            67-69" for the 1a101GCM, 68 was the middle of the road....
            • #36
              I agree on the prop comments.
              I run a 72-42 Sen on my 85-8.
              Cruise is about 80-85 on floats @ 2400rpm.
              Motor will run past 2700 if you leave the throttle all in during flight!
              The other problem I see is weight, 894lbs empty is brutally heavy IMO!
              Any idea what the extra is from?
              My plane is 775lb on ski's with 8-10 gls of gas.
              46 BC-12D Taylorcraft
              46 Chief
              • #37
                Originally posted by senior View Post
                ...My plane is 775lb on ski's with 8-10 gls of gas....
                And
                Really? 8-10 gal is 48 to 60 lbs. I didn't think the wheels weighed that much compared with skis. I pared my 46 BC12D down to a realistic minimum (albeit with skylight and the two wing tanks) and I came out at about 815 lbs empty.
                My pre-war that I used to own (lighter than the post-war as we all know) was 777lbs empty of fuel.
                • #38
                  Tim,
                  Yes, normally it would be too short.
                  But is not to short for this airplane because it has been properly modified by a field approval in 1998 for this prop.
                  • #39
                    Someone give me a link to a Continental document for the 85 that says I can put a 74 inch prop on my -85 and I'll start looking for one to buy tomorrow. I would love to have that extra 2.5 square feet of thrust area.
                    • #40
                      Hi Darryl,
                      Airplane TCDS gives 72" and 71" max. for Sensenich and McCauley respectively but I bet you knew that.
                      McCauley TCDS for 1B90/1A90 gives that larger diameter IF the max. RPM is 2600 (look at the eighth line down).
                      See attached.
                      • #41
                        McCauley 1A90/CF (seaplane only) 24 lb. (-32)
                        Diameter: not over 75 in., not under 73.5 in.
                        Static r.p.m. at maximum permissible throttle setting:
                        not over 2600, not under 2500
                        This is for the o-200, i am still looking for something with an 85 on it in seaplane configuration...Tim
                        For Model 8A seaplane with item 212 floats. Any 1A90-CF propeller which meets the
                        following limits:
                        not over 2170, not under 2070
                        No additional tolerance permitted.
                        Diameter: not over 74 in., not under 72.5 in.
                        (This propeller change dictated by undesirable vibrations in the static r.p.m. range with
                        the model 1A90-CF-7142. McCauley Service Bulletin No. 12, dated June 2, 1949,
                        covers the same subject).
                        • #42
                          And
                          Apoligies
                          After checkin my notes....
                          (I guess seniors shouldn't rely so much on memory!)
                          Weighed on the ice last winter (tail down) with scales, left-370lbs, right 390lbs, tail 82lbs =842lbs
                          Less fuel puts it right 800lbs or slightly less.
                          I still think 894 empty is heavy?
                          & a 70-40 prop seems like it would be spinnin it's wheels.
                          46 Chief
                          • #43
                            Thanks guys for looking around for info on 74 inchers. Appreciate it.
                            Dave, thanks for the PDF. That is going to take some attention. I have to work out how that one ties in with the Taylorcraft specificatlions.
                            Have to check my prop today for sure. Think it is a 71 or 72, maybe about X46. This is not a high priority on my to-do list, but since I do mostly short local flights high cruise efficiency could be sacrificed a bit for a better climb rate.
                            All it takes is money, right?
                            • #44
                              Yes for sure, merely money.
                              • #45
                                Apoligies
                                No apology necessary, Senior . Of course the weight is the same with a scale under each wheel in whatever attitude. 1 + 2 + 3 = weight.
                                The only reason to do the old "weights & measures" activity in a level attitude is to get the cg position.
                                800lbs +/- is about right, in my opinion, for a post-war BC2D.
                                As an aside, and for general interest only, there are fewer than 15 airworthy Taylorcraft in the UK. Some pre-war; some post-war and I have weighed most of them.
                                Only one came out as less than 780 lbs, and that was a pre-war with minimal equipment.
