I purchased some new sealed struts from one of the suppliers back in January 2008 after the AD came out. I remember them coming very well packaged and primed with what appeared to be a reasonably tough green primer, so I wiped the primer down and painted them with a two-part etch prime (to adhere to the existing primer), then two-pack epoxy primer then two-pack top coat.
They were fitted to my aircraft in about April 2008.
Last year, a little bit of corrosion made itself apparent, so this annual I decided to strip them back. In some areas, large sheets of the primer almost fell off; in others it's quite well attached.
You can see from the photos below some of the corrosion that did not show through the paint. Note that I did not use powder-coating. Note also that there was no bead-blasting prior to their primer coat.
To be fair to the Supplier, these struts are now six years old, done about 450 hours. The corrosion is not what I would call "significant", so it's just a warning to those who purchased new sealed struts at about the time the AD came about to be vigilant.
If you had your struts powder-coated, be extra vigilant! It could take many more years before the coating shows evidence of surface corrosion.
