Im seeking information on the repair of spruce spars, It is permissible to splice a spar according to AC 43.13 but not under an attach fitting, what Im not sure about is does that mean the splice joint cannot be under the attach fitting or can the splice be made away from the attach fitting . Some one in this group will know ?
Spar repair
Re: Spar repair
As long as the splice and reinf. plates don't interfere with a fitting your ok. There may be min distance from a fittng as well, I'd have to look that up again.Originally posted by waltermrich View PostIm seeking information on the repair of spruce spars, It is permissible to splice a spar according to AC 43.13 but not under an attach fitting, what Im not sure about is does that mean the splice joint cannot be under the attach fitting or can the splice be made away from the attach fitting . Some one in this group will know ?
Re: Spar repair
I've found through past experience, that it's more economical to just replace the spar than going through all the work of a splice...especially if you have to pay someone to do it. I'm sure there are many that will disagree, but that's my preference. To get the splice exactly right is quite a bit of fitting and work.... just sayin'.
Re: Spar repair
Originally posted by N96337 View PostI've found through past experience, that it's more economical to just replace the spar than going through all the work of a splice...especially if you have to pay someone to do it. I'm sure there are many that will disagree, but that's my preference. To get the splice exactly right is quite a bit of fitting and work.... just sayin'.
Re: Spar repair
You really should have a look at AC43.13-1B. the repair criteria your going to use is spelled out very well.Originally posted by waltermrich View PostSo from what Im reading if you found a damaged area near the root attach fitting of a spar you could cut the spar back far enough and splice anew piece in place reglue doublers and that would be permissible.
Re: Spar repair
There are lots of things you "can" do, but there are also a lot of them you can fix a better way. If I had a spar with a break in the last two feet at the tip I wouldn't hesitate to splice it. If I had one broken in the first two feet at the ROOT, I would make a clip wing spar out of it or replace it. You "can" splice it, but I wouldn't without some static testing after I did it, and it would be cheaper to just make a new spar with the testing I would do.
Re: Spar repair
Originally posted by waltermrich View PostIm seeking information on the repair of spruce spars, It is permissible to splice a spar according to AC 43.13 but not under an attach fitting, what Im not sure about is does that mean the splice joint cannot be under the attach fitting or can the splice be made away from the attach fitting. Some one in this group will know ?
I don't see the difference between these two options. What did I miss?
Can you find a good experienced restorer in your area and consult with him or her?
Spar fixing is an old problem that has been solved many times in the past they will walk you through it.
Re: Spar repair
Originally posted by waltermrich View PostSo from what Im reading if you found a damaged area near the root attach fitting of a spar you could cut the spar back far enough and splice anew piece in place reglue doublers and that would be permissible.Last edited by N96337; 03-23-2014, 09:56.I'm so far behind, I think I'm ahead
Re: Spar repair
One of the things I found challenging in concept was how to fit the ribs over the thicker part of the spar that has the plywood "overlay" (forgot the real term, that was a long time ago). Made a few test splices with resorsinol (sp?) and found the spliced area to be stronger than the main body of the wood, even without the overlay. That was back in the mid 80's. I still have the resorsinol. I've often thought about testing a bit of it to see if it still works. Chuckle.
DarrylLast edited by flyguy; 03-26-2014, 17:29.
Re: Spar repair
Very carefully! They need to be installed in a specific order...Tim
Originally posted by flyguy View PostOne of the things I found challenging in concept was how to fit the ribs over the thicker part of the spar that has the plywood "overlay" (forgot the real term, that was a long time ago). Made a few test splices with resorsinol (sp?) and found the spliced area to be stronger than the main body of the wood, even without the overlay. That was back in the mid 80's. I still have the resorsinol. I've often thought about testing a bit of it to see if it still works. Chuckle.
DarrylN29787
Re: Spar repair
Originally posted by stearman3 View PostPS. you're right, NEVER UNDER A FITTING!
As a result I got me two beautiful wings,and zero time on it all.
Just say'n
Birdlegs...Last edited by birdlegs; 03-27-2014, 06:10.
Re: Spar repair
I would think it would be lot easier to remove 3 or 4 ribs to reach a broken part of a spar than to dissmantel an entire wing to replace a spar, wood when kept dry and in the right climate will last decades and decades .An expericened wood worker would have no problem creating a scarf joint that would be stronger than the spar itself.
Re: Spar repair
Originally posted by waltermrich View PostI would think it would be lot easier to remove 3 or 4 ribs to reach a broken part of a spar than to dissmantel an entire wing to replace a spar, wood when kept dry and in the right climate will last decades and decades .An expericened wood worker would have no problem creating a scarf joint that would be stronger than the spar itself.
I don't think anyone is saying it can't or shouldn't be done. What they are saying is based on their experience working on airplanes that you would be better served replacing the spar instead of trying to splice it. I know that is what I would do. I think trying to make a splice on a spar that is still installed in the wing will be tougher than you think. I can't imagine trying to do precision machining on a spar that is still attached to the rest of the wing.
