Hi all,
I am assembling a wing and installing bolts and fittings.
I have the drawings for the parts and a clearance can exist between the i.d. of the bushings in the wing and the bolt that goes through it. (its not a t-craft wing
So that means that some bolts fit tight and some loose.
I have one or two bolts that do fit loose.
I recall that in the past I have made such bolts fit tighter by smearing it with epoxy or varnish...
Epoxy seems to aggressive as the bolt may not come back out unless perhaps I coat it with a release compound.
My reason for posting is this; does anyone have any any experience or suggestions about what compounds or process may be good the fill in that clearance, provide a tight fit and allow the bolt to be removed later?
Thanks, Dave.
Thanks, Dave.
