Wheelpants for '41 Deluxe
  • #31
    Re: Wheelpants for '41 Deluxe
    Well, I said I would post a picture and I can only hope it works.
    Tom T
    • #32
      prewar pants have a vertical riveted seam. postwar pants have a chrome strip down the middle.
      None of pre war that I've seen have a riveted seam. One half has a vertical flange, and the other side has a vertical flange that lays against it and wraps over and back down like a "U" channel.
      • #33
        Tom, I'm sorry, but those are not original '41 pants. They look to be maybe a mid 60's Cessna style pant. Tom
        • #34
          you are correct, it was a folded seam.
          • #35
            that is a homebuilt wheelpant. we installed quite a few cherokee wheelpants and always looked good.
            • #36
              I will try and check the logs to see what they are.
              Tom T
              • #37
                I was wrong, what I have match's nothing mentioned here so far! No seam of any kind, I forgot to knock on them to see if they are glass.
                L
                PS: As you can see they are still mounted on my bird still sitting in the dirt floor hanger, but the rent is $0.00/month
                • #38
                  Larry,
                  Those are Aeronca pants, pretty common to see fiberglass reproductions on Taylorcrafts, if those are original metal and not fiberglass, they would be worth a bunch.
                  NC39244 '45 BC12-D S/N 6498
                  • #39
                    L
                    Larry,do you want to sell your along with the mounting hardware?
