Need Tiedown Rings
  • Need Tiedown Rings
    Anyone have a set of tiedown rings for sale? I need the type that clamps to the strut. I just need the rings....I can make the clamps. Thanx!
    MIKE CUSHWAY
    1938 BF50 NC20407
    1940 BC NC27599
    TF#733
    Re: Need Tiedown Rings
    I do and I still need to find that strut for you if you still need it. let me know
      Mike,
      I was able to get (4) stuts to pass testing. They are not pre-wars. If you can find one of the skinny prewar rears, I would be interested. Probably the same section as those used on the Model A's.....I will send you the major and minor axis dims later today.
      George called with (2)tiedown rings last night. Thanx for the response!
      MIKE CUSHWAY
      1938 BF50 NC20407
      1940 BC NC27599
      TF#733
        Originally posted by 1938BF50 View Post
        Mike,
        What is a "skinny pre-war" worth?
          Dave,
          The last (2) rear struts that I bought (larger than my originals and only one passed inspection) were $100 ea. I would pay the same for another one of the proper size. I need a strut that has a minor/major axis of 1" x 1 3/4" nominal.
          Do you have one?
          MIKE CUSHWAY
          1938 BF50 NC20407
          1940 BC NC27599
          TF#733
            I have a 1.8" x .98" (its bent) and a 1.7" x .75" that is not bent.
            I am not sure what I am going to do with them yet but had considered cutting them for use in repairing landing gear cabane struts.
            I am not sure if they are the size you were looking for.
              Dave,
              Unfortunately, I could have used the bent one. Those dims are exactly what one of mine reads. Thanx for looking!
              MIKE CUSHWAY
              1938 BF50 NC20407
              1940 BC NC27599
              TF#733
                Dave,
                Hi Mike, so being bent makes is unusable for you? Did I get that right? Dave
                  Dave,
                  I assumed it was bent beyond use? PM me a phone# and I will call you to discuss.
                  MIKE CUSHWAY
                  1938 BF50 NC20407
                  1940 BC NC27599
                  TF#733
                    Does anybody know what the cast rings are made from? When I was in college we used to cast aluminum in a barn/garage and the process was dirt simple. The alloy we used was called Pistalloy (we melted old VW pistons down).
                    The rings are NOT very strong and I just wonder if a local foundry sand cast them or if Taylor did them behind one of the buildings.
                    How many need them? If there are enough it would probably be worth carving a pattern (NO, you can't just use an existing one, they shrink as they cool) and sand casting a bunch of them. Pass out the rough castings for the owner to finish as an owner produced part.
                    This isn't NEARLY as hard as the engraving has been, or even the pre-war "D" window frames.
                      I had an airplane totaled from those aluminum rings.
                      Wind was strong and one pulled into two parts, airplane flipped over.
                      Only use them to hold the rope in position. What I mean is thread the rope thru it and then around the strut and tie it off so that the rope is holding the strut not the ring.
                      I did make some steel versions of the rings and I still only use them as mentioned above.
                        Dave,
                        Excellent advise....I will remember that one.
                        MIKE CUSHWAY
                        1938 BF50 NC20407
                        1940 BC NC27599
                        TF#733
