Need an A-65 Oil Tank
Need A-65 Oil Tank
The shout mount tank has the dent, the long mount can clear in some installations with a regular tank. I know the O-200 big 6 quarts clear the long mount and the C-90 had either a small or big tank that would fit only the long mount.
I have like 5 tanks, the one I have with a dent to clear the short mount looks like a golf ball, I would not dare sell it. The others are short necks. Maybe someone else on here will have a good one.N29787
I have a short neck tank that I was getting ready to list on barnstormer. It was an extra from hanging the new motor a year ago. Shoot me a PM if you are interested and I can get you some more pictures etc.Stu
'46 BC12D
Jefferson County (0S9)
Yes I believe so. It had the same dimple area as the tank I used on my C85. (I reused the tank I had from my a65 because it was a long neck with a speed drain I trusted already on it.) But I test fit both and they both seemed to work. My c85 is also on a short mount.Originally posted by astjp2 View PostStu, do you know if it does it clear the short mount?Stu
'46 BC12D
That is good, it would work for him then. TimOriginally posted by Kerbs View Post
Yes I believe so. It had the same dimple area as the tank I used on my C85. (I reused the tank I had from my a65 because it was a long neck with a speed drain I trusted already on it.) But I test fit both and they both seemed to work. My c85 is also on a short mount.N29787
