F-19 Cowl
  • F-19 Cowl
    Any chance anyone would have the nose bowl and lower cowl for an F-19?
    Jim Taylor, Lowell AR.
    Re: F-19 Cowl
    Lower cowl is flat sheet that can use a little massaging in the English wheel... you can use the nose bowl from Univair...tim
      Re: F-19 Cowl
      Thanks! I had huge bumps, but didn't like them, so I was thinking of skirting clear around the exhaust like a super cub. But I may stay with bumps. Any thoughts?
        Re: F-19 Cowl
        Are you running the 150 exhaust? Tim
          Re: F-19 Cowl
          Jim,
          I have a lower cowl that lays flat on the ground in the parts pile. Would cost a fortune to ship but a tracing on a big piece of paper would be easy. Would a tracing help?
          Got to dig it out. Being flat, it is probably on the BOTTOM of the pile!
            Re: F-19 Cowl
            Hank I would like a tracing of a bottom flat cowl, is it for a F-19?
              Re: F-19 Cowl
              No idea. I got it with a bunch of other Taylorcraft parts. I just remember that when I laid it down it flopped out completely flat. All my planes are pre or barely post war (40, 41 & 45) so I know almost nothing about the later Ferris planes.
              I will try to dig it out next time out at the airport.
              Waiting for the repaired mag to get back from the shop to get the 41 running again.
                Re: F-19 Cowl
                I would also be interested in a tracing if possible, just getting started on upgrading 1941 n29747. I have access to scanners and cadd. Could get into email form for others if interested.
                Getting c85-12 overhauled as we type. could use some guidance on starter and generator for short mount.
                Thanks. Paul
                  Re: F-19 Cowl
                  Thanks. Paul
                    Re: F-19 Cowl
                    Thanks. Paul
                      Re: F-19 Cowl
                      Looks like this one might need to be more than a simple tracing. When I find it I will start with a simple trace for Jim (or whoever wants to verify the shape is right.....it COULD be the reason I have it and it isn't on a plane is it is messed up!) Once it is verified the shape is good I can do a real drawing and maybe we can have it digitized so anyone can take the file to Kinkos and get it printed full size.
                        Re: F-19 Cowl
                        The only starter that will fit on the short mount is a B&C starter also the little B&C alternator works well also a side note you also need to change the exhaust system to either a Luscomb or hanlin walker from a cessna 150.Look up my engine change to n26658 lots of photos. Chuck
                          Re: F-19 Cowl
                          Chuck,
                          Just curious, do you have to pull the engine to remove the starter?
                            Re: F-19 Cowl
                            NO but you do need to drop the top mount bolts out and let the engine drop down to get it out.
                              Re: F-19 Cowl
                              Thanks Chuck
                              i will look for photos
                              Paul
