I'm looking for a bungee cover for my L2-B. It is the stramlined tubing type and I only need one. If you just have just the wood part I can take that too, my metal part is ok and I can put new fabric on. I just don't have the capability to form the wood part. E-mail me at [email protected] if you can help.
Bungee cover wanted
Re: Bungee cover wanted
sure you do, got a bath tub?Originally posted by n6346m View PostI'm looking for a bungee cover for my L2-B. It is the stramlined tubing type and I only need one. If you just have just the wood part I can take that too, my metal part is ok and I can put new fabric on. I just don't have the capability to form the wood part. E-mail me at [email protected] if you can help.
Ragwing,
That is a legitimate question for this neck of the woods, but yes I do have a tub. Don't I have to make a form to obtain the right shape? Does just folding the part give it the proper shape on its own?
Originally posted by Ragwing nut View Postsure you do, got a bath tub?Bob Picard
N48923 L-2B Skis/Wheels
Anchor Point, Alaska TF#254
Ammonia is a common trick amongst the balsa airplane crowd. The ammonia breaks down cellulose and makes it pliable then the cellulose re-hardens when the ammonia evaporates.
That does not sound like a good idea to do with plywood, but hey, the Germans formed the Albatross with a full monocoque plywood fuselage... so all ya gotta do is find a really old Albatross mechanic and ask if they used ammonia.Best Regards,
Fold will give very close to the proper shape. works better with hot water. Ammonia works better, but would not recommend due to the amount required. All you need for a form is to jig saw 2 pieces of ply wood to the correct shape and then use staples to hold the plywood in place as you bend it around. Plywood must be fully dry before you glue itOriginally posted by n6346m View PostRagwing,
Thanks Ragwing, I'll give that a try.
Originally posted by Ragwing nut View PostFold will give very close to the proper shape. works better with hot water. Ammonia works better, but would not recommend due to the amount required. All you need for a form is to jig saw 2 pieces of ply wood to the correct shape and then use staples to hold the plywood in place as you bend it around. Plywood must be fully dry before you glue itBob Picard
Got this this morning from Koloman Mayrhofer. This guy is a real expert on WW-I plywood and manufacturing with it. Check out
and be ready for a LOT of fantastic reading. Even if you are not into WW-I planes like the Albatros this guys work is true art.
hallo,
There is not a single part in the Albatros covering which needs special treatment beside of soaking with water. In ww1 plywood was casein glued so steam was not an option. The design was layed out in a way that the material can be used without to much problems. We do have a problem nowadays in as far as the phenolic resin glued plywood
is much stiffer than the original, but have the advantage of using hot water.
There was a limited production of blood albumin glued plywood in the United States during ww1 which could have been steamed but I have no proof if in which aircraft this material was used .
cheers
Koloman
