Climb Prop
  • Climb Prop
    Our BC12D has a Sensenich number W72GK 44 prop, which is a great Climb-Prop but we could use some more "cruise" !
    Our engine is a C85 with "Don's Dream Machine" components so it has plenty of power.
    Appreciate any suggestions on alternate cruise-props !
    Thanks, Jack Ryder
    Have it repitched cheaper than buying a different one. Your mechanic can handle getting that done.
      Not sure how you would repitch a wood prop.
        Sandpaper!
          I have reworked a few model propellers looking for better performance, but I find it hard to make much change to the pitch without losing too much of the blade.
            Sorry, trying to be funny!
              I was too, at least somewhat.
                current performance? static? cruise? max rpm in level flight?
                  At 2,400 RPM cruise we are doing 85-90 MPH.
                  At full throttle in level flight the engine will do about 2,700 RPM. ( 200 RPM over Red-Line )
                  Jack
                    Back when I was building Falcon (Fahlin) props, I built a 74/45 that performed very well on 85's. try to find a prop to borrow and test before deciding on replacement.
                      What might be a good metal prop to consider ?
                        What does the STC give as parameters for the propeller? I think that would be a good starting point.
                          74-46 or 72-48, 74 are hard to find without paying dumb money
                            I had a 74-43 on my o-200 powered deluxe and loved the climb. I had to keep it wrapped up to get any speed out of it. I also ran the 69-50 on it and while it cruised good, climb sucked.
                              85 is limited to 72 inches in diameter from what I remember, or maybe 70”
