Re: Things to look for , when rebuilding wings
The picture below of the broom-handle pieces that I found in my wing (between the butt-rib and the wing tank) are just a reminder to look out for any questionable work that may have been done in the years between the factory and your ownership.
Also, the 1/16" plywood reinforcing plates beneath the aileron hinge hardware (on the aileron spar) just fell off when the hardware was removed. I cleaned up the area and glued on new plywood.
