Looks like I need some help again. I intended to install my horizontal stabilizer but came upon a problem. Only one of the two forward bolts will fit. It's the same on both sides. It would appear that only one bolt was in place when I disassembled it three years ago. I honestly can't remember. Can anyone tell me, is there only one bolt holding the front of each stabilizer in place.
The two bolts won't even fit through the stabilizer by itself as the two bolts interfere with each other. If its only one bolt, which one should it be, the vertical or the horizontal?
