Team,
Anyone have the "correct" length measurements for the B-80 Tube Tie Rode at Lift Strut Fitting? I have several from a couple of disassembled wing sets and they range in length from 30 1/64" to 30 1/16". Checking to see if situation is simply due to manufacturing tolerances or is these are "file to fit" upon installation. Also, as there are shims on the internal wing drag strut installation, can someone provide the main spare to aft spar centerline-to-centerline spacing dimension.
Many thanks.
Many thanks.
