Re: High performance piston options for the O-200
ive seen that the ma3 spa carbs were used on several different models and hp ratings .. what would be nice is to see the individual throat sizes.. in our c85 we dont have mixture control really this makes me think we are just underserved...
might be nice to get a trial and see if there are improvement in going up in throat sizes
Still an O-200D that was used in the Cessan 162, 100hp
Originally posted by swoeric View Postid like to see where we end up with just a valve job and compression and a cam
run a composite prop and call it good
Ill try to post a pic of my exhaust when i get out to the hangar
Originally posted by astjp2 View PostOh, you meant an O-200D?
Originally posted by PA1195 View PostMy guess: The right prop for the speed; balanced engine; raised compression (at least mid-9's) and low friction piston/rings, fuel injection, but maybe still a carb; cold air induction; tuned and smoothed intakes; bench flowed ported heads with proper stepped valve/seat grind; cam for the rpm and job with low friction components; tuned exhaust to max cylinder fill and volumetric efficiency at race rpm; electronic ignition and maybe a knock sensor if available. Stuff like that makes fireworks that go fast but may not reach TBO.
Forgot light weight synthetic oil like OW-30 to reduce pumping loss and save the bacon from getting fried.
GaryLast edited by PA1195; 05-08-2017, 23:45.
Yep, we need Victor Bravo to come back and give us the rundown on the engine he used at Reno!
Formula 1 aircraft racers would know what works to improve performance and what doesn't.
been following this some. and wanting to come up with a solid recipe myself
if we lighten the rods and pistons the crank will also have to be rebalanced to match them.. it would lead us to vibration in an underbalanced situation if the crank is not lightened..
i would like to see what a solid multi angle valve job would do.
the crank could be reprofiled and somebody like crane cams would do it when you provide intake length chamber volume and rpm etc..
the other way to gain some lift would be changing rocker arm ratio. I think we could probably find or have drop in rockers for less than factory ones would cost
so according to the service bulletin SB00-3a, the IO360 connecting rod 646116 supersedes the original o-200 rod, so the new one that is 147 grams more is the current rod to use....along with the associated bots and nuts
well at 2700 rpm, the mass wont mean much, and I have a rod that came out of a 145-2 that looks a little twisted...
Originally posted by astjp2 View PostBingo, its the IO 360 rod, but only 1 casting that I have found is a heavier one. I have seen the same casting number as the O-200 used in an older IO360 with the corresponding bushing. this isn't really for certified applications, but for a hotrod motor if someone wants to build one. TimLast edited by Ragwing nut; 01-04-2017, 21:12.
Originally posted by astjp2 View PostSo I have been doing some research, I found another continental heavy duty rod that is the same dimensions as an O-200 connecting rod but it weighs about 140 grams more than the stock rod, way more stout...Tim
Well they are similar to a hotrod car rod, I was thinking that they could be c-n-c machined to reduce weight. Horizontally opposed engines are inherently balanced, with some light weight pistons? who knows what the potential for a hotrod motor..oh and the stroke is the same for both engines...Last edited by astjp2; 01-01-2017, 21:14.
