Re: Trim Adjustment Screw - B12-406
Yea, it is going to be a problem, but depending on where you live and how long between recovers it may not be worth worrying about. You have already seen what happens with regular steel screws. They are way less noble than aluminum and because of their alloy are even less noble than structural steel (said plainly, they RUST, usually locking in place). Back when we covered planes with Cotton, the plane would require recover before the screws got so bad they couldn't be removed. With the synthetics we use now covering lasts DECADES and the screws rust in place. One good solution is to put the screws in wet with primer to reduce the corrosion. The problem will be less for the next generation because we have a LOT more respect for our planes than the last 50 years. Most of us take better care of them than the typical "ramp rat" Taylorcraft of the past. The stainless will cause the metal you are screwing into to rust instead of the screw, but the screw heads may sheer off if they are "stuck". At least with a SS screw the drill bit will tend to follow the softer screw instead of the base metal. In 20 years just get some left hand drill bits to remove the stuck screws.
Or do what I did and rib stitch. ;-)
Originally posted by drude
View Post
