F-19 Trim
  • F-19 Trim
    My F-19 trim seems lacking...barely able to trim to 60mph...I don't have much time in an F-19, buts lots in BC-12D 65 I rebuilt 45 years ago as a kid...it could trim for less than 50 if I recall correctly...all specs and angles have been checked...thinking of adding a trim tab to trim tab...any thoughts from anyone....Thanks and 73's, Lynn
    Re: F-19 Trim
    Full nose-up trim and throttle closed, and hands off, your F19 should descend at about 65mph.
    What does it actually do?
      Re: F-19 Trim
      That's about right, maybe 60...just feels like to much forward CG...I've been carrying some tie downs and tools and stuff in back and it feels a little better ...but not as nice handling as old N43213 did...I only have about twenty hours on this F-19 scattered over a few years...I'm sure I need more time to learn the 'edges'!
        Re: F-19 Trim
        If it has more than enough nose down trim, it can be adjusted so you would have more nose up trim and less nose down trim. MAC
          Re: F-19 Trim
          it is going to feel that way due to the foward cg from the engine placement. which prop does it have on it.
            Re: F-19 Trim
            Can't remember the prop right now...it is the standard one...I think only one was approved...I think same as 150 Cessna
              Re: F-19 Trim
              It is a 6950
                Re: F-19 Trim
                It is also approved for a longer 1b90 cm7443 prop. Its going to fly with a more foward cg feel. It also wheel lands better than a bc-12d becuase of the foward cg as well. Personally out of all the taylorcrafts I have owned and flew, not counting the L-2M, I preferred how our F-21 flew the best.
                  Re: F-19 Trim
                  Well the old BC12 D flew better to me...I prefer three point landings and shorter landing distances...Thanks everyone.
