BC12-D A65 to A75 Conversion
  • BC12-D A65 to A75 Conversion
    Hi folks,
    I've just finished a BC12-D restoration for a gentleman who came in with an A75 already installed. When I was going over the logs to make sure everything was in order I saw that there was no approval for the installation of the A75 back in '99 when it was installed. I've looked over the previous posts regarding this topic but can't find what I'm looking for - someone who has had this installation done AND has the paperwork to back it up. It would likely be something along the lines of an FAA field approval or a one-time STC. Any help would be appreciated.
    Charles D. Stence, A&P/IA
    RTS Pilot, SEL - Complex, Hi-Performance, Tailwheel
    Ragwing Restorations
    772.245.6701
    Re: BC12-D A65 to A75 Conversion
    Charles,
    Give me a call and lets talk over the circumstances. I'll see what I can do to help.
    (254) 715-4773
    barnstmr@aol.com
      There is suppose to be a "Damon"?? 337 somewhere but I have never been able to get my hands on a copy. It is suppose to be a 337 early enough to be used as acceptable data.
      L Fries
      N96718
      TF#110
        Charles,
        I sent you a pm. I would like to know more about this installation.
          How long has the 75 been on the airplane? One year? Five years, 10 years. How many times has it been annualed with the 75 on it? How did others miss this? JC
            Thanks for the replies folks. I should have what I need now to get a field approval from my FSDO. I'll be sure to post a copy of the 337, should it go thru, so others will have the paperwork readily available.
            The only trick now is trying to come up with a suitable "case" for a static RPM range on the field approval, as opposed to a single prop. If the owner wants to repitch in the future, he would technically have to get another field approval. Fortunately, Palm Beach Prop has been a great help and provided some prop application info which should look "official" enough for the FAA.
            772.245.6701
              Since we're on the topic, I've found something else that many seem to be confused about - how to convert an A65 to an A75. I work on these little guys all the time and always assumed everyone used Continental SB M47-16 to convert. This service bulletin, put out by Continental, basically specifies waffle pistons and oil squirt holes in the rods. The only way you actually get the extra HP is by changing the prop - the engine changes are merely for cooling to handle the extra RPM and power. In several places on this forum I've seen folks talk about a "jet change" for the carb. No where in the Type Certificate or the Service Bulletin does it call for this - I even asked a carb shop about it and they said the A65 and A75 carb are identical. I've attached the Continental SB. Does anyone know if maybe there is an alternative approved method (STC etc) to get the extra 10 HP? Just curious.
              772.245.6701
                From my hotrod years I learned an engine is like a big airpump. The three major ways to get more power are more cubic inches, super chager - turbo charger, or turn the engine faster. And yes I know there are other ways such as valve lift and valve timing, changing the flow of the cylinder heads, intake and exhaust work ect. ect. ect.. George
                  I thought the jetting change was for the 85 HP engine, but I AM NOT an engine guy!
                    I guess a STC would be required for the A75 installation. But an A65 with some A75 internal parts should still be an A65. If the data plate was A65 or A65 CONV it would still be an A65.
                    EO
                      I have done approvals or been involved in certifying various ways...
                      1. Engine with A65 data plate but rebuilt with A75 parts. Then stamp the data tag with "-C-A75" after the "A65" model number.
                      2. Airplane conversion removing an A65 and installing an A75 (or A65-C-A75). This can be done two different ways.... either with 75 hp rating or de-rated with 65 hp rating.
                      • The 75 hp rating for a Tcraft means that a different propeller is required as mentioned.... one that would allow the engine to turn faster RPM (statically and at takeoff). To certify this way, quite a few CAR 4 regulations come in to question by the FAA such as structural adequacy of the frame, engine cooling, etc. While the answers to these questions may be simple, some FAA inspectors don't see it this way. So its easier sometimes to certify with 65hp. Then there's not much in question because its the same. I used to do these approvals until about 2004, when the FAA changed the rules. Now STC is required almost exclusively across the FAA. You still might find some FAA inspectors who see this as straightforward and allow it to go through as a 337 with a DER approval or a 337 with "field approval".
                      • The 65hp (de-rating) means the engine is still an A75, but you use a prop that matches up to the A65 static and takeoff rpm. This would then limit the A75 engine to 65 horsepower by limiting the RPM (In other words - keep the original prop). This is the simplest way for some FAA inspectors to understand that it is OK to install an A75 in place of an A65. I have done several DER approvals this way in support of 337s. The FAA allows this without STC.
                      Whichever route you go, it needs to be clear to the pilot with the instrument markings properly matching the power rating as certified.
                      barnstmr@aol.com
                        I'm not so sure you want to put the A75 on. By the time you get a prop to spin up to rated RPM you don't have enough prop to pull the plane. And your fuel burn goes way up.
                        You can check out TCM Service Bulletin M75-6r1. It has some information on conversion of engines, not much, but some.
                        EO
                          I definitely see your point about slowing down with an A75. However, it isn't me who wants to do the upgrade, it is the owner. Keeping it an A65 would be much easier from a paperwork point of view....
                          I'm still waiting to hear back from the FAA.
                          772.245.6701
                            New information....
                            I missed a crucial piece of info. Apparently the fellow who did the engine overhaul installed the "75HP" mods to convert the engine to an A65-14, NOT an A75-8.
                            According to the Continental Type Cert:
                            "Model A-65-14 differs from A-65-8 only in that it incorporates special pistons, rocker arms and exhaust valves, seats and guides."
                            Unfortunately I can find nothing in the Continental Conversion SB about details for this conversion. Anybody know anything about it?
                            772.245.6701
                              Originally posted by CStence View Post
                              New information....
                              what is a -14? i know what a c90-14 is, but never heard of an a65-14.
