Re: BC12-D A65 to A75 Conversion
The -14 engine actually makes 75HP at 2675RPM, which means whenever this engine is installed it probably has a higher operating RPM, just like an A75 does.
However, even if this was the same 65HP, it is still considered a major alteration because what is installed is different than what was originally installed (-14 as opposed to -8). That increase in HP (15%) makes it not only a major alteration, but one that can only be approved with an STC, according to the FAA. What I want to do now is de-rate the engine and operate it at 65HP (Not exceeding 2350 RPM in level flight). This should be straight forward since the engines are nearly one and the same (if operated the same).
Update: I have contacted a DER in Georgia who has been very helpful should approve the data for this (derated -14 installation) just as soon as I type it up for him. Then I'll just have to send the 337 to Oklahoma and we're home free.
Originally posted by Edwin Otha
View Post
