From what I've read if I use an engine with no logs or plate I can maintain it with new log book stating
A new logbook can be generated to log maintenance and condition from this point on.The initial entry would read something like this: "Previous logbooks lost, hours unknown."followed by a summary of the work you have detailed below.Any attempt to make an estimate of previous hours on the engine will carry no weight as you cannot verify the hours and when the engine was overhauled.In essence, you will record the current condition of the engine with no reference to the past, and continue to operate the engine on a conditional basis until inspections or operational experience indicate that an overhaul is required.Once the engine is overhauled, the clock can be re-set and a more traditional set of logs can be generated using the date of the overhaul as a documented starting point.
Is this the case?
Is this the case?
