Airframes: Clip Wing Taylorcrafts
    Kevin- Thanks a million. Looks like I am saving about 15 pounds for the set of clipped all wood wings. Every ounce counts! I want to try and keep it at 750 pounds or less. I plan to do a good bit of acro and eventually some airshows. With the limited power of the 0-200 I will need to keep it light.
    Eric Minnis
    www.bullyaero.com
    Clipwing Tcraft x3
      80# wing
      Eric
      Mine had the tank in the wing too and im still saying 80#
      B 52 Norm
      1946 BC12-D1 Nc 44496
      Quicksilver AMPIB, N4NH
      AOPA 11996 EAA 32643
      NRA4734945
      Somewhere on the 38 parallel in NE Arkansas
        Wing Wieght
        Your welcome Eric,glad I could help.My stock wings should be a little lighter than most because I didn't put a bunch of epoxy primer/paint on everything,I used Vari-prime self etching primer on everthing and it is a lot lighter than the epoxy.So you are probably save a little more wieght than you think.Also I relized that the tip leading edge was off of one of the lighter of the 2 wings,that's probably where my wieght difference came from.
        Good luck with it.We need to get together someday and do a few aerobatics.
        PS. I thought I would remind you about the door frames while I was thinking about it.
          Wing weight
          Hay Crispy
          the question that was not asked is are they the 15 stamped rib wings like mine , or the 13 rib wings.
          To B or not to B , that is the ?
          B 52 Norm
          NRA4734945
            Norm, the 13 rib is the 1150lb gross pre-war wing, 15 rib is 1200lb post-war wing
              Wing weight
              Ok Robert
              Let me get my head out of my butt
              Now what i meant to say is "Stamped or structural ribs"
              I do believe , as in i know, the BC12d had both , what i don't know is was there a weight difference?
              B 52 Norm
              NRA4734945
                The ribs are interchangeable (except the stitching question).
                My 45 BC12D has 15 built-up ribs (1200lb gross)
                My 46 BC12D has 15 stamped ribs (also 1200lb gross)
                  Ribs
                  So Robert old chap
                  You say the ribs weigh the same. Now figure that rib lacing thing out for us will you?
                  I HATE WIRE HANGERS
                  B 52 Norm
                  NRA4734945
                    Norm I don't say the ribs weigh the same...I do not know.
                    But the stamped ribs are not approved (I believe) for stitching, although I understand the new F22's will be stitched.
                    I am still looking for a 337 for stitching the stamped ribs.
