My experimental clip wing has a 150 Lycoming in it, with slick mags for ignition. The left mag wires/cap sits right up against the firewall to the point that several of the wires are tweeked pretty good. Does anyone have a suggestion as to the "path of least resistence" to a better solution?
1) Modify the fire wall with a pocket? The problem is their is a horizontal frame support running directly behind the firewall in this exact location.
2) Some kind of "extended" motor mounts to gain 1/2 inch clearance?
3) Modify, re-weld the engine mount, and recalculate the CG?
4) Some kind of 90 degree wire cap?
5) Install a different mag/ignition system on the left side?
