Re: Glare-shield
It will be different for every plane. The boot cowls and frames are pretty different from plane to plane. I had a couple of pretty good looking ones in metal and none fit either of my planes or were the same as each other. I ended up using some poster board from the grocery store and just fitting it up as best I could and used tape to fill in the short areas and some small scissors to trim the long areas. Took a couple of tries but ended up with a glare shield pattern that was withing 1/4" all around. Laid that on top of the Hat Shelf material and cut it out to match. Some rubber edge channel seal closed up the gap and I put a piece on the aft edge for a nice finish.
DON'T get it wet if you use the hat shelf material!
I can trace some of the ones I have if you really need a starting place, but they won't fit.
