Fuselage Serial Number
  • Fuselage Serial Number
    Where is the serial number stamped on to the fuselage?.....a fellow looked somewhere oi the left side of the cockpit on a bare fuselage and came up with a SN#, but I can't find one on mine.......
    Look on the inside of your throttle control mount,the flat piece of metal that hangs down below the insturment panel that your throttle control,carb heat,fuel shutoff,etc. is fastened to,it should be stamped on the back side facing the gas tank,firewall,etc.
    Hope this helps.
      My serial # was on the top RHS door hinge.
      Cheers
      jCandlish
        20442 has the sn stamped in the metal channels that are the swing out window locks. (pre war).
        20442
        1939 BL/C
          pre-war are on the door hinges plus the early ( Dec-Jan) BC12D. then they went to the throttle plate....
            Re: Fuselage Serial Number
            KEVIN.,
            What ever happend, to the Red 1977, F19 it belonged to MR.,George Dillon ,Windsor Ontario Canada.,
            i know you did not know it was stollen ,at the time ,but thought if you had any leads that
            George or his Son George JR, would be only to thrilled to know were his 1977 Taylorcraft F19 ,
            ser #085 ,ended up, or if you had any idea ,or had heard any thing.Thank you for any help you
            could render,dont get me wrong im not saying any thing bad about you as i know your a stand
            up guy .have a great day Sir.
            Paul
              Paul,
              You may have wanted to send him a Private Message so the whole forum isn't wondering what you are talking about. Just a suggestion.
                Re: Fuselage Serial Number F 085
                M Towsley
                Thank you
                SIR
                Paul
                  Other than on a data plate, is there a serial # on the L2?
                  Bob Picard
                  N48923 L-2B Skis/Wheels
                  Anchor Point, Alaska TF#254
                    On the backside of the rear throttle. As Forrest told me, that is considered as the whole airplane. Everything else is just parts attached to that throttle.
