Does anyone know where to get the phenolic tubing that goes into the the fuselage where the aieleron cables come thru and attach inside. There is a guide that these things run thru and that is where I need to replace the guide.
Phenolic tube
Re: Phenolic tube
Good morning Ray. I got mine from Forrest Barber at the Foundation. If you want to take a different approach, do a search here for "fair leads", there is quite a discussion about making them yourself. I went the easy route, since Forrest had a large number of them in stock.
Re: Phenolic tube
Check out an industrial supply like McMaster-Carr or the other one whose name escapes me.
I believe that the phenolic tubes are all standard size electrical insulation raw stock or industrial raw stock.
When I worked in a ball bearing factory in the 70's those phenolic tubes od all sizes were all around and were used to push races thru a centerless grinder.
Point being that I think its a common item.
Re: Phenolic tube
THey dont fit a Tcraft, they are for a cub. been there done that. Tim
Originally posted by Richh2only View PostAre these what you are looking for, Aircraft Spruce has Cable Fairleads for $2.75 each.
Go to this page and search for Cable Fairlead
Richard Herzberger
N43178 Member # 1072N29787
Re: Phenolic tube
Richard Herzberger
How about search for Phenolic tube? They do sell assorted sizesDale
T.F.# 1086
