Fuel Shut Off Dificulties
  • Fuel Shut Off Dificulties
    The main tank (BC12D)fuel shut off is very difficult to move. We have dissasembled it polished the parts and re-installed it with no improvement. Just wonder if control rod or valve arm can be modified
    for better leverage?
    Re: Fuel Shut Off Dificulties
    Did you put any Fuel Lube or I think the new name is EZ Turn lube on the parts. That is manditory maintenance on a Piper and it really works.
    Lyn Wagner
    Formerly N96290
    TF# 1032
    KLXN
      As Lyn suggested:
      This amount will probably last you and your friends the rest of your life. And if you share some with your enemies, you will most likely have more friends than before. Dick
      Dick Smith N5207M TF#159
        Ditto to all the above
          Thanks very much, I have ordered it.
          Thanks again to all.
          Jim
            Yep works great until the valve begins to drip...Tim
